The pump has not failed yet. I need to drop the tank to blow out the vent line going between the EVAP canister and the tank. This truck is 11yrs old. My thinking is that if I have to drop the tank I may as well replace the pump while I'm there. It's a 26 gallon tank 1/2 full so about 13 gallons at 6lbs per gallon equals nearly 80lbs I'm wrestling with on my back in the driveway. If it had a relay I could bypass it and use the fuel pump to pump the gas out of the fuel rail pressure relief valve. But why make it easy GMC.
there is a fuel line disconnect on the intake, not sure where else.
i have not tried to do something like this myself, but if you disconnect the line and have some method of catching it like a larger line fitted over it and tied close you could feed the fuel into a gas can with the key on. not sure if you would have to cycle the key or if you could just leave it on run, etc
someone else with more knowledge may chime in
