Gas pump keeps stopping when I fuel up.
Rick10Tahoe
There is a video showing how that clip works. It helps to know how and where to squeeze. I think I used a flat head screwdriver pressing the button and a 5 in 1 painters tool to twist the connection off at the same time and while laying on my back
homesick
The Best Me I Can Be
Did you have to turn your ball cap around backwards?
joe
C
Chvytahoe11
Got it!! These truck hasn’t had a full tank of gas in a while I did noticed that the gas pump kept stopping after 3/4 of a tank, every gallon or so
petethepug
Michael
SoCal
A shout out to AT&T linemen and techs. You guys are the best. In our SoCal beach city we’re still on the orig copper lines or overloaded 1970 cable TV wire orig made for channel 2-13 +UHF.
When our AT&T copper $35 mo 30 mbps broadband rotted out all the way back to the switch out tech said (in confidence) RUN!
He referred us to Costco to get a T-Mobile 5G unlimited wireless router for $30 mo. Ironically the only other option, that cable company we may have had to go with is Named just like their customer service, CÖX.
When we used to use CŌX I discovered they’ll still cash your check each month if you make it out to Cöcks.
mountie
Home connections are limited, to the old hardware buried, between you and the main source.
It took me 3 times to get the latest router..... They try to give you the old crap, to dump it.
petethepug
Michael
SoCal
* Line/Service men .. Rock.
* US Service was A+ but they farmed most of it out overseas.
Sorry for taking it off topic …
The gas pumps here in Cali have that annoying vapor recovery system built in that has to be maintained or they stop the fuel delivery.
Fortunately e85 & diesel do not have the rubber snorkel over the filler nozzle. Either upside down or twisted to whatever side you can does keep the flow sensor in the handle from shutting it off.
mountie
After moving from Kalifornia, ..First thing I noticed...... Here in Florida, I don't get any odor while pumping gas, as I did in California. Florida has no "recovery" ....
raejay
