DJTricky
Banned
so its settled i think im gonna be going turbo. im gonna be meeting up with 95twintt this weekend so we will be talking some info.
...A proper installation of a centrifugal S/C has power right off an idle as does your Magnacharger.
...That Link you point to, is over 3 years old and seems to favor certain brands. There have been several improvements since then.![]()
How is this achieved? Mine, according to the dyno runs, kicks in around 2500 at WOT.
QUOTE]
I’m not familiar with the ProCharger. I’ll just explain what I went through with my Vortech. The original kit, came with two injectors that were in a block that went between the TBI and the intake. It was controlled by a black box, looking at intake pressure.
The system came with a 3.33 inch diameter pulley on the blower. Crank pulley I believe was 8”. The 95 Tahoe was a slug from the factory. This kit made it come alive. The gas pedal was all of a sudden extremely sensitive. It just jumped off an idle. I drove it like that for about a year, loving every minute of it. Then I started noticing oil leaks. Turns out the increasing blow-by was causing enough positive crank case pressure that things that would normally not leak, were leaking.
I decided to just pull the engine and fix whatever it needed. I found the stock pistons and rings, were not real happy about having a blower leaning on them. Since I am into the “might as well” syndrome, I dropped the engine off at my favorite engine builder and said, make it tuff.
That’s when the AFR heads and custom pistons and cam came in. When it was back together again, I decided to up the boost. I went down to the 2.75” pulley.
Now I was reaching 15 psi boost. The 3.33 pulley would top out at maybe 10 psi. The blower spec’s say it can do 20 psi boost and 1,000 CFM @ 50,000 rpm max.
I have been pushing it way beyond the 50,000 rpm’s. That worked just fine for a long time, until I discovered the Vortech getting noisy. I sent it to the factory. Next I got a call from the technician working on it. He asked how cold it was where I was? I said, depends, but it was about 10 degrees that day. He said, you can’t run the SQ (super quiet) in cold weather. So he rebuilt it with the straight gears, like the T trim has and no problems after that, but it had that significant whine you get from the straight cut gears.
This is from Vortech’s web site. They list their pulley sizes as 3.33” 3.12” 2.95” and 2.75”. Then they go on to say, “A change in 1 pulley size will usually effect boost 1 – 2 PSIG…… Down in diameter, up in Boost and Vise Versa”.
I certainly found that to be true. I guess I would say, you should see noticeable power coming off idle. The dyno run’s generally start around 3,000 rpm’s, so that doesn’t mean much for the low end. They take a few hundred rpm’s to establish the load against the engine before they are reading right. My dyno sheets are almost horizontal lines after it gets up to speed.
I would not hesitate to go down a size in pulley size, if for no other reason, than, you cannot be getting close to 62,000 rpm,s the way it is. Plus 99% of driving is just normal cruising, so it certainly won’t hurt the S/C at all, even if you were able to get it over 62,000 once in a while.
The only concern to me would be your “tune”. Were there additional injectors included with your system, to compensate for what the blower was adding?
That would definitely get it moving off the idle is you don’t think it is enough now. The other thing is, if you still have the stock piston rings and all, expect a sooner visit to the parts store for new pistons and rings, relative to how much more you up the boost.
You may also be up against octane issues too. I’m running 92 octane all the time with alcohol injection when under boost, starting at 5 psi.
I also want to go back to my original kit for a moment, I noticed a hell of a change in power with the original 3.33” pulley and no alcohol on a stock engine.
The specs on your ProCharger are higher and more impressive, than my S-Trim. It would seem like it would be doing the job and then some
