Identifying 2013 6.2 Tick (attached video)
thefrey
2013 Yukon Denali 6.2 199k. AFM not deleted. Intermittent tick. 15psi hot idle and maybe 22psi cruising at 1800psi. Fresh full synthetic 5w30 oil changed about 800 miles ago.
Yukon is new to me, I bought it at about 197k. Last owner said that they replaced the lifters at about 190k but who knows.
The tick is very intermittent. Can be heard sometimes when the engine is fully hot, but sometimes there is no noise. Tick sounds more prominent while near the wheel well(s). It seems to almost always happen when the engine is cold but is very much 50/50 when hot. I did a "warm" start today after truck had been sitting for an hour or two and didn't hear a tick on startup
What are the chances that it's an o-ring issue? I've heard that a bad oil pickup o-ring can sometimes cause a clatter. Not sure though. I'm also not sure if it sounds more like an exhaust leak or a mildly sticky lifter.
I can't really tell, sounds like a noisy injector to me. Get a long extension or mechanic's stethoscope. Stick one end in your ear and touch the other end to parts you suspect the noise is coming from. If you have long hair, get it out of the way of the accessories spinning 'round and 'round lest you scalp yourself!
Oil pressure is lower than normal. Probably too low for AFM to turn on.
thefrey
thefrey
Here's another video perspective from the passenger side wheel well
Yup, AFM won't activate when hot. It does when it's cold though with the higher PSIs. Not sure if the AFM not activating would affect any lifter tick
On another note, found 1 stud broke, a couple missing bolts, and a bolt halfway out on the manifold. So maybe that could be something as well
donjetman
@thefrey
Sounds like a valve train issue to me.
Could be:
loose/worn rocker arm
lifter preload incorrect
bent push rod
broken valve spring
thefrey
thefrey
@thefrey
Could be:
bent push rod
broken valve spring
I haven’t had the privilege of getting this deep into an engine before lol. What’s the best way to diagnose something like this? Should I start by taking the valve cover off and observing from there?
Also is a collapsed lifter out of the question here? Not exactly sure if the noise could be a lifter issue
j91z28d1
fix all the broke bolts first.
rip mattock
