05goatls2
- Joined
- Jun 10, 2011
- Posts
- 46
- Reaction score
- 0
Hey guys, just installed a new accell coil into my truck. When I was performing a tune up last week I noticed the plug connection going to the distributor was very corroded so i decided to replace the coil. upon replacing the coil and starting the truck it idles very low, and is rough.... then it jumps up to about 1200rpm and the service engine light comes on. Obviously it's the coil. I did remove the distributor cap to get better access to the bolts for the old coil. Also note I had to dremel the brackets off the coil and dremel them down to fit the new coil. What could be causing this? I also smell that the truck is running rich. When I did the tune up I replaced cap and rotor, plugs and wires.
