ravingmadman
Chief Knuckle Buster
This is the list of parts I've had to replace, with the date and cost. We're taking bets on what goes up in flames next. Feel free to play. No purchase necessary, void where prohibited, results may vary.
The Official Replaced/Involuntarily Upgraded List:
purchased vehicle 5/21 $2000
front brake pads 5/23 $21
rear brake shoes 5/23 $20
rear brake drums 5/23 $120
rear brake cylinders 5/23 $10
front wheel bearings 5/23 $300
idler arm 5/23 $20
alternator 6/6 $100
fuel pump 6/13 $220
radiator 6/17 $250
lower radiator hose 6/17 $20
all battery wiring 6/21 $50
pitman arm 6/24 $20
tires 6/25 $1200
rims 6/25 $400
battery 6/25 $60
alignment 6/26 $60
rear shocks 6/26 $100
front diff u-joint 7/12 $5
driver side half shaft 8/22 $70
used upper control arm/bushings/ball joint 8/29 $60
lower ball joint & pressing 8/29 $70
used spindle/hub/disc/caliper 8/29 $70
used front diff with *correct* gears 8/29 $300
new rim 8/29 $90
new rear end 9/14 $400
alignment 10/1 $150
front disks turned 10/7 $30
front brake pads replaced again 10/7 $60
moog poly sway bar bushings 11/1/09
moog poly sway bar bushings (again- rough handling during summer ) 11/5/10
driver's side catalytic converter 12/20
idler arm 5/23 $20
alternator 6/6 $100
fuel pump 6/13 $220
radiator 6/17 $250
pitman arm 6/24 $20
tires 6/25 $1200
rims 6/25 $400
battery 6/25 $60
alignment 6/26 $60
new rim 8/29 $90
alignment 10/1 $150
