Ignition Timing
msark
My distributor was changed recently. I have been told that there is a timing setting that can only be read from the obdII and a higher end reader.
Can someone please tell me what the setting is??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
CAM_RETARD.
For 1997's
TEST PROCEDURE
The ignition timing cannot be adjusted. The distributor may need adjusting to prevent crossfire. To insure proper alignment of the distributor, perform the following:
  1. With the ignition OFF, install a scan tool to the DLC.
  2. Start the engine and bring to normal operating temperature. IMPORTANT: Cam Retard Offset reading will not be accurate below 1000 RPM.
  3. Increase engine speed to 1000 RPM.
  4. Monitor the Cam Retard Offset.
  5. If the Cam Retard indicates a value of 0°+/-2°, the distributor is properly adjusted.
  6. If the Cam Retard does not indicate 0°+/-2°, the distributor must be adjusted.
ADJUSTING PROCEDURE
  1. With the engine OFF, slightly loosen the distributor hold down bolt. IMPORTANT: Cam Retard Offset reading will not be accurate below 1000 RPM.
  2. Start the engine and raise engine speed to 1000 RPM.
  3. Using a scan tool monitor Cam Retard Offset.
  4. Rotate the distributor as follows:
4.1. To compensate for a negative reading, rotate the distributor in the counterclockwise direction. 4.2. To compensate for a positive reading, rotate the distributor in the clockwise direction.
  1. Repeat step 4 until 0°+/-2°, is obtained.
  2. Turn the ignition OFF.
  3. Tighten the distributor hold-down bolt to 3 Nm (25 lb. ft.).
  4. Start the engine, raise engine speed to 1000 RPM and recheck Camshaft Retard Offset.
asdfcars
