davidbeaver1
Here is my saga in short... 2005 Tahoe LT 4x4, 160,000 miles. Last September, transfer case started leaking, pump rub caused it, had transmission guy replace back half of transfer case with new and improved case and new pump guard. All good. 3 weeks later, transmission starts leaking fluid out of the shifter seals. Any time you get over 70 mph, starts leaking, and dripping on the cross pipe causing smoke. Back to the transmission guy to get transmission rebuilt. Got on this forum and got direction on how it should be rebuilt. It took until January to get all the parts and finally get it rebuilt. All good. 3 weeks later, going down the interstate and see smoke in my rear view mirror... What the... Ran by my trusted mechanic, he says transmission is dry, its oil from the oil pan gasket and valley cover. 3 more weeks it sits at his place while he replaces gaskets to stop all of the oil leaks. I get it back yesterday and take off for work 2 hours away this morning. About an hour and 15 into the ride, what do I see out my back window? Smoke rolling off my truck... I pull over and transmission fluid is everywhere! So I limp back home making sure to not go over 60 and stop by my trusted mechanic. He says that the transmission dipstick seal is where it is leaking from. Wouldn't you have replaced that seal when you rebuilt the transmission???
I'm about ready to trade this thing and get a Honda....
