I'm about done...
YukonRog
Auburn, CA
Didn't your mechanic have to drop the Transfer Case in order to replace the back half? If it were me, and I did this, I'd have the TC rebuilt while it was out. Also if I were under that vehicle and saw transmission fluid all over I would have checked the pan bolts. Very common for them to loosen. The end may be near for you with the transmission dipstick though. Once it's replaced it may be good. I'd degrease everything and drive it then look again. Like my Yukon, it's had it's share of problems but once you replace or rebuild everything it's good to go! After all, what is your vehicle but used parts? Another used vehicle (sometimes new one's) can be a whole new can of worms.
Bill Barnes
Catlett, VA
Am I just lucky? I bought my 2005 Yukon XL 5.3L 4L60E Flex Fuel 4X4 new with 4 miles on the odometer b/c it's a Southern Comfort conversion. At 82K, I did have the dealer replace the transmission because when they serviced it there was excessive metal in the pan. I now have 233K on the Yukon, and have never had an engine oil, Trans fluid, or transfer case leak or additional problems with any of those components. I have always done the recommended maintenance on the vehicle.
Like many of the other longtime members of this forum, I will probably never replace this vehicle. I believe from everything I have read here over the last 6 years that the 2005-2006 Tahoes, Suburbans, and Yukons/XLs are the best that GM has built in the past 30 years. I'm 71 now, and I can't see how I can justify spending nearly $100K to buy an equivalent to my current ride.
MassHoe04
Western MA
I have an 04 with over 212k miles. Not an 05 or 06, but I would tend to still believe this to be one of the best ever produced...
Everything is good so far. Drives and runs beautifully and very reliable as my daily driver.
I am not messing with engine or transmission unless something happens.
mikehooo
Here is my saga in short... 2005 Tahoe LT 4x4, 160,000 miles. Last September, transfer case started leaking, pump rub caused it, had transmission guy replace back half of transfer case with new and improved case and new pump guard. All good. 3 weeks later, transmission starts leaking fluid out of the shifter seals. Any time you get over 70 mph, starts leaking, and dripping on the cross pipe causing smoke. Back to the transmission guy to get transmission rebuilt. Got on this forum and got direction on how it should be rebuilt. It took until January to get all the parts and finally get it rebuilt. All good. 3 weeks later, going down the interstate and see smoke in my rear view mirror... What the... Ran by my trusted mechanic, he says transmission is dry, its oil from the oil pan gasket and valley cover. 3 more weeks it sits at his place while he replaces gaskets to stop all of the oil leaks. I get it back yesterday and take off for work 2 hours away this morning. About an hour and 15 into the ride, what do I see out my back window? Smoke rolling off my truck... I pull over and transmission fluid is everywhere! So I limp back home making sure to not go over 60 and stop by my trusted mechanic. He says that the transmission dipstick seal is where it is leaking from. Wouldn't you have replaced that seal when you rebuilt the transmission???
I'm about ready to trade this thing and get a Honda.... :mad:
hang on to it you got everything fixed now
davidbeaver1
davidbeaver1
Siler City, NC
Ok, finally got to drive it on a 600 mile trip this week. Ran it up and down I-95 and it ran great. Got it up to 83 mph a couple of times just running with traffic. After about an hour of that, I started smoking again (fluid leaking onto exhaust pipe). Just ran it up on the lift and it is definitely coming from the transfer case vent hose. So to recap, the transfer case originally started leaking oil because the pump beat a hole in the case. The transmission guy replaced the back half of the case, and installed a pump saver, that's all. Once he did that, its been one problem after another.
What could cause the transfer case to push fluid out of the vent hose once you reach 80 mph? I drove the rest of the way there and back at 75 and no leaks. Nick, you may know this one...
NickTransmissions
Sin City
The transmission bench
Fluid is expelled from the vent tube for two reasons:
1) too much fluid (usually no big deal other than causes a bit of a mess)
2) too little fluid and the fluid that is in the tcase or trans is overheating and pressure from the excess heat is pushing more fluid out the tube.
Check level by removing the fill plug and see if anything comes out. If not, stick a finger in the port to see if you can feel fluid. If not, add until it pours out of the fill plug then reinstall the plug.
GMT800 SUV/Trucks
Reminder: if you want to tag a member, start by typing the "@" sign and the start of the username, then select that person from the picklist. Like this: @NickTransmissions.
Also, I found out something else, when you do the @ sign and start to type in their user/screen name, you do not have to include capital letters.
saul02
