Im gonna burn the damn thing.
retorq
Kingman AZ
You redlined the temp after it ran for a few minutes? Something tells me that's not an ECM issue.
Bigsteve04Ho
Sounds like a head gasket blown
Sent from my Nexus S 4G using Xparent Skyblue Tapatalk 2
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you don't simply just jump a tooth and it just stays that way with no more issues on thee same part. at any rate there would have been a code popped for that.
---------- Post added at 10:23 PM ---------- Previous post was at 10:20 PM ----------
i would consider looking into getting some live data including gm specific data for iac data and cam retard setting.
foxrider251
foxrider251
Edson, Alberta
retorq i should have mentioned that i had my foot to the floor for that few minutes trying to get the ***** to break 90 kmh. and it didnt redline but it was getting there so i shut it down, and where would i find that live data SunlitComet? sorry not trying to sound like an idiot stick but all this is way past my mechanical comfort zone im just trying to get this thing back on the road any way possible
_Dylan_
STAY FROSTY
Your buddy with the mac tools scanner will be able to pull live data.
SunlitComet
OBS Jedi-Do Good
break 90 km. have you considered a partially plugged exhaust system? or week fuel pressure?
---------- Post added at 06:00 PM ---------- Previous post was at 05:59 PM ----------
and yeah your friends scanner should do fine.
foxrider251
foxrider251
Edson, Alberta
i was pissed off so i tried just matting it onto the highway, and as far as fuel preussue we should be able to eliminate that seeing as how it has a new fuel pump, new spider assembly and a fairly new fuel filter
raptorforme93
Tampa, Fl
Is it just me or should it still not almost overheat like that even when floored, which I also wouldnt do with your engine conditions. Did you check the coolant levels and oil to see if it looks all milky??
foxrider251
foxrider251
Edson, Alberta
yeah i know it wasnt the best thing to do, gotta learn to control that temper lol and yeah i checked the oil and coolant for any signs of a head gasket issue (ive had a chevy 350 with a bad headgasket before) but nothing. it will only heat up when you put throttle into it as soon as you let off it cools right off. its also now just started idling at 2000 rpm by itself and will do so until i shut it down. tried several times and does it everytime so basically its booked in to go get looked at in the next couple days. this godamn thing is all over the place and i just really dont want to damage anything internally engine-wise because she still is my baby after all and i love driving it not doing an unneccesary engine jobs. guess ill stop being cheap and get the pros to figure it out :/
dda1
