I'm sure I'm not the first person.
ecordell
CordellDesigns.com
Merica
I've had this idea runnin through my head since I saw the LED conversion table that is stickied. www.superbrightleds.com has some bulbs on the front page that look like they might be replacements for turn signals/brake lights/reverse lights. Am I crazy or has anyone else thought about trying these and see if they would work on our trucks. Is there anything else that would have to be done?
Cobra
Austin, Tx. area
thought about it after I saw a Silverado on IH-35 that had some really white daytime driving lights. I assumed they were L.e.d.s because they were so white & bright. I would still like some. Need to look into it.
nytahoe
"Tha Butcha"
new york
drls will kill reg leds. i have burnt up a few pairs lol. v-led has some the are made for gm drls but 50 bucks. dont feel like 50 bones for leds a worth it.
Grocery Getter
A guy with a truck.
Phoenix, Az
You just need to put some resistors inline on the DRL's, turns, backup, and corner...I've been running mine for over a year now with no burn outs. I go through a set in my plate lights like every six month but I ordered like 40 of them on Ebay for like $10......... there was a write up somewhere, it may have been on the old forum....
Travieso
Boooooooost !
Los Skandeles, CA
Grocery Getter Can you link me up or do a Write up I would really like to look at this write up since i do have LED all around, And have that rapid Blinkers annoying as hell ricers always trying to race me, LOL
Cobra
Austin, Tx. area
Yeah I remember something about them burning out & adding resistors to manage the power to keep them from doing this. IS thier a write up on what is needed & how they were being installed. I've wanted to do this will just the driving lights anyway.
Grocery Getter
A guy with a truck.
Phoenix, Az
Sorry to be such a dousche and not have a link but it was a long time ago and the old forum is gone. I will see what I can dig up when I get back from vacation next week............when I get home I can look in there and see which resistors I wired up and all that jazz......
Cobra
Austin, Tx. area
Not a problem bro. just wondering if anyoine had the info. or maybe something new has come out since then. Have fun on your vac. :Handshake:
nytahoe
"Tha Butcha"
new york
ive heard that you can use this on the drls and will fix ur fast blink. about half way down
http://autolumination.com/equalizers.htm[/URL]
Note: Equalizers heat up, like a light bulb. Install so that they do not contact plastic or painted parts.
Led Protector
Designed to help protect any led bulb from power and voltage surges
Got a vehicle that eats leds??
Helps protects LEDS from premature failure - Designed to works with any 12 volt led bulb
Common causes of Premature LED Failure
Switching on the ignition & starting the engine while the leds are switched on.
Changing or disconnecting the battery while the leds are switched on.
Charging the battery with an auxiliary battery charger, or revving the engine hard with a weak or dead battery while the leds are switched on.
Using jumper cables while the leds switched on.
Excessive AC voltage due to damaged diodes in the alternator.
High system or circuit voltage.
Voltage surges caused from switching on and off amplifiers or other peripheral add on devices that use a lot of power.
Faulty or out-of spec. voltage regulators.
Installation Diagram
$1.99 ea.
Choose Color
Red
Choose Type
Led Protector
***Click Here to add a tracking number to your order***
You don't run your computer without a surge protector do you? Why risk damage to your expensive leds?
yooformula
Milwaukee, Wi.
seems like an easy fix with that. when I installed leds in my taillights/blinkers in my other car, I used a different flasher relay and it fixed the rapid flashing.
cwmccray_jr
