IMPORTANT: The Chronicles of Low Oil Pressure by 07burb
TraumaTruck1
Decatur, AL
I am wondering if you either had an oil passage clogged, or if you had some sludge build up that was breaking loose and clogging the filter. That engine flush may have taken care of either.
Good luck. I hope that works out.
BRUTUS_T_HOG
In my experience the oil pump relief valve gets stuck open causing a loss of oil pressure intermittently. The motor flush additive probably loosened up some sludge and allowed the valve to move freely
Fink117
Did you run the Rislone for an entire 3k mile cycle or did you add it towards the end when you did the oil change.
Administrator
Through the entire 3k mile cycle
Administrator
Should turn over 150k this week and running strong since doing the treatment described in the first post of the thread :)
08grey
It's funny how so many people call products snake oil and have never used any of them.
Glad it worked out. Good info. Thanks. Never thought of looking into risolene products.
tswelsh
