in need of a hid relay harness
rippinitup
NY.
looking for a relay harness. if someone can link me to the right direction. 35w hids.
ezdaar
Chat Troll
Redneck central, Aka Houston
Build one.
If you must have plugs then you going to have probs.
If you are able to solder wires, building a Harness will get you a much! better relay setup, that wont melt fuses, plugs or have POS relays.
Kman
Southern California
i have one from them, just bought. and it doesnt work. i dont feel like dealing with them right now. looking for somewhere else. lol
Plugging into the headlights is reverse polarity. Flip the plug and plug them in. Should work.
Vinniety
Westchester, New York
Just out of curiosity why do you need one? Does your HIDS not work at all, maybe one works and not the other??? As someone just stated i had to turn the plugs around because of the polarity being different. I also posted a few days ago having issues with my new HID fogs from DDM and instead of ordering a harness i found it to be a bad ground. DDMtuning also has a great knowledge base section. That actually helped me for both issues i had when i purchased mine. Good luck.
rippinitup
rippinitup
NY.
thanks for all the info and links.. i need it for my parents van. its a 2011 toyota sienna. i bought the whole kit from ddm. the hids work with out the harness but i'd rather use the harness. i tried flipping all the connectors every way possible (at least i think so) but nothing. cant get them to fire up through the harness.
