Installed a Spohn adjustable pan-hard bar!
BOSS
The People's A D M I N
Dallas
Wow what a difference from the OEM stamped steel bar! I could tell a difference just backing out of the drive way. Rear end is more solid, no flex in the panhard bar, and honestly it makes the front end seem a little less stable.
Not only the stability has dramatically improved but I was able to adjust the rear end since dramatically lowering the truck affects the rear end alignment with the stock OEM ph bar.
NORCAL SS vendor from this board carries them cheap but here is the one I bought:
http://www.spohn.net/shop/2000-2006-GM-SUV-Suburban-Tahoe-Yukon-Avalanche-Escalade-Hummer-H2/
BOSS
BOSS
BOSS
Dallas
Was that a typo or does it make the front end LESS stable?
No, it just feels like it because the rear end is so much more solid...does nothing to the front end.
Not a SM fan honestly, each their own though.
B
BOSS
BOSS
Dallas
And you have dual front stabilizers right?
Yes and I'm going to start a group buy thread...they'll be $200-225, worth their weight in gold man...I make the brackets myself, as they are nearly impossible to find...pics soon
B
Modded
That Guy
B
Me neither, he seems to be pretty cocky.
But I do like his taste in Tahoes, I may try this Spohn out soon but I would prefer a black one if there is one.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no more sleeve issues. All the ones i have they are not a problem :)
also i have them in both red and black and i will have the 07 up bars here in about 4 weeks.
WybotYukon
