Phone Man
Hey everyone. Just got the motor installed. It was a *****. FYI try and move the transmission and transfer case back as if you were doing a car. I tried to avoid it and it took a while to get those dowels lined up.
I also installed the VMAX manifold spacer and a Ported Throttle Body from CFMtech.com. I will go into detail on another thread but for now I need some tips on what is going on with the truck.
I don't think the computer is able to adjust to the mods. In particular is the idling. In the morning I have to get on the gas a little in order for the truck to idle. Then at a light it will surge to around 1100. At another light the idle will fluctuate almost into a stall. Driving seems ok but shifting and passing gears are erratic.
Maybe the throttle body mod is affecting the idle air control valve? Not sure here. I definitely need to get a data logging tune from black bear but I need to clear up these issues first.
Any help is appreciated.
