installing a back-up camera
Ron C
Ron C
Los Alamos, NM
Wiper motor? Where are you trying to install the camera?
I just removed the black plastic cover. That gave me access to the nuts holding the plastic trim. Popped it off and installed the camera.
The black plastic cover, as the trim on the inside of the tailgate?
Ron
Ron C
Ron C
Los Alamos, NM
The write up with pics seems very helpful, we'll see once I get into iyt. What I heard from the "amp and harness guy:"... the camera plugs into the harness in my case. "That's why that RCA plug is there" amp/harness guy said. So that part should be easy.
Ron
Chuck_Finley
I just watched that write up, seems like the wiper motor, and the trim where the bezel goes, use the same screws/bolts.?
Ron
I believe they are separate - the wiper motor has its own 3 bolts that need to be removed to access the screws for the applique.
Ron
Makes sense, I connected an aftermarket camera to an aftermarket radio so it was just the power 12v+ and RCA cable I had to run forward. I also had to drill a hole in the applique to mount the camera, you shouldn't have to do that going factory.
Ron C
Ron C
Los Alamos, NM
I believe they are separate - the wiper motor has its own 3 bolts that need to be removed to access the screws for the appliqué.
Makes sense, I connected an aftermarket camera to an aftermarket radio so it was just the power 12v+ and RCA cable I had to run forward. I also had to drill a hole in the appliqué to mount the camera, you shouldn't have to do that going factory.
Right, I still have to cut/drill a hole in the 'appliqué' .. for the camera (and what are the round holes for?). Do all of these model Tahoes have the wiper motor there? Somehow I have the impression that it might be quite a bit easier to get those nuts off (of course now I jinxed it), routing the cable/coax should not be 'that' difficult, I already figured how to do that with running an antenna cable. Although, taking the trim off (and merely putting it back on might be a pain. (I just finished doing that on my Grand Cherokee, replacing a lock actuator. Took me 2-3 days to even get the hatch open, without having to destroy the trim. At least the tailgate of the Tahoe opens.
Ron
Chuck_Finley
If you mount an aftermarket camera, you'll have to drill it. It's not that hard to get the bolts off, just a pain is all. It was worth it for me since I pull a boat trailer and I wanted to be able to line it up easily.
Ron C
Ron C
Los Alamos, NM
Maybe that's just a "model year difference" ?
Ron C
Ron C
Los Alamos, NM
Yeah I have a trailer too, sitting in a barn, camera would be real handy, to not hit trailer and barn doors.
A few hours is worth the time... besides, it's pretty cool toy to have too,
I want the "factory, OEM one.. but still have to cut a hole in that "applique" thing... I can see an outline in that piece of trim, but no cover or holes or anything.
I think I just need to get one (amp guy told me he has those too, with instructions on how to hook it up to the stereo head unit. Once I have one that would work, I'll figure it out doing it.
Ron
Ron C
Ron C
Los Alamos, NM
Were the nuts/bolts actually done with Loctite? or not? What was "the pain" getting access to it? I do have airtools, that makes sinning the nuts easer... as long as I can get a socket in.
Chuck_Finley
Not sure about the loctite, the issue was mostly access. The guide I linked before describes it in detail, good luck.
Ron C
Ron C
Los Alamos, NM
I zoomed in on that pic where it was unbolted. It doesn't seem like there was loctite on it. (of course there might be some crud/rust etc. ) The issue is probably the studs being molded into the plastic, and possible stripping (heat probably isn't a good idea either)
Sounds like a fun project.....
Ron
Wikked00hawk516
