Kpwweb
- Joined
- Dec 11, 2015
- Posts
- 728
- Reaction score
- 321
Thank you!!
I kind of am suspect of his cable routing around the A-Pillar, feel like the cable is likely obstructing the side curtain Air Bag, should it ever need to deploy.I finished installing the parts and everything worked prefect
The parts you need
15-20' CADILLAC ESCALADE CHEVY BOLT OEM REAR VIEW MIRROR CABLE CONNECTION | eBay
What vehicle will this work on?This will work on any vehicle you are doing a OEM rearview mirror conversion on. Will this work on a Cadillac ESV?Yes, it is long enough.www.ebay.com84784545 Video Display Inside Rear Camera 2020-2023 Buick Cadillac Chevrolet GMC | eBay
Part Number: 84784545. 2022-2022 Buick Enclave. 2019-2021 Cadillac CT6. 2021-2023 Cadillac Escalade. 2021-2023 Cadillac Escalade ESV. 2020-2023 Cadillac XT5. 2020-2023 Cadillac XT6.www.ebay.com13536995 Inside Mirror with Auto Dimming, Video Display, Pre-crash Cadillac GMC | eBay
Part Number: 13536995. 2019-2021 Cadillac CT6. 2021-2022 Cadillac Escalade. 2021-2022 Cadillac Escalade ESV. 2020-2023 Cadillac XT5. 2020-2023 Cadillac XT6. 2020-2023 GMC Acadia. 2019-2022 GMC Sierra 1500.www.ebay.com
I did a little digging on the GMpartsdirect and it looks like they only break out the cameras from that whole module. That intermediate bracket that holds the cameras within the larger plastic frame is not a sub-part, at least the way GM has the parts catalog setup. If you need just that bracket it looks like you'll either need to find one at an auto-wrecker or E-Bay...Reviving this to see if anyone has run into this... The part number for the rear camera housing is no good anymore although still available on ebay. I ordered the mirror, camera, cable, and rear housing for the dual cameras. The problem I've run into is that the housing for the dual cameras didn't include the plastic plate that holds the cameras in place. So I can't secure the cameras. I can't find a diagram or part number referencing the back plate so I'm not sure if it's a separate part number or if the housing should have included it but it was missing. I tested everything before I started the install and it's functional but I can't finish the install because I can't secure the cameras.
