Installing power port and USB in the back
it's pretty easy to just run wire from the battery under/along the frame and up in behind the tail light, that is how my subwoofer amp is powered
PG01
Up here to the right
That's really cool!
I wonder if those connectors are available as pigtails anywhere? That would make it super easy to wire something up.
Yes, I ferget where tho...that stuff is there for upfitters... the companies that make ppvs, ssvs, etc. Gm puts them there for ease of wiring diff options. Sort of like a plug and play option for up-fitters. At some point i had a linkto the connector that fits and it came with 6” wire leads but a a female spade connector fits on the pins but you should verify which pin is carrying which voltage...
bullrunlover
