interior cabin filter how to remove
Big Mama
Virginia
Remove the glove box remove the screws from the cover of the filter housing then swap them out. Be sure to vacuum it while in there.
how do you get access to the cabin filter 2008 xl
your 2008 may or may-not have one
if it does then you remove the kick panel on the passenger side under the glove box and there will be single screw to take out and then remove the cover plate to get access to the filter.
if there is no filter cover and it is just solid plastic, you can buy a retrofit kit (dorman makes them) you would take a razor kniife or sharp tool and remove the plastic slot in order to insert a filter and the kit will have a new cover plate and screw
I don't know if the 2008 model year had a cabin filter. My 2007 Yukon XL Denali did not come with a cabin filter. There was, however, a spot where the cabin filter could be installed with a kit. The installation process was not difficult, and now with the kit, I have a functional cabin filter.
RicksTahoe69
