Interior LED How to
Hart
According...
According to the list, you want 4 T1.5 replacements. Like so. I favor superbrightled's, as well.. I'm the average layman, and I can figure out what I need, and get it.
I -think- you'd want the bulb's ending in 74 off this list, but I'm admittedly the last person to listen to on that one.
raptorforme93
Tampa, Fl
@ BlackedOutHoe- What color bulbs did you use when you replaced them? I want to change all the lights and want to do the color that you did. Thank you!
rdhenderson
Bellingham, WA
So I have replaced 95% of the interior lights to LEDs. However, I have something strange happening. When I went to replace the lights for the instrument panel indicators the 2 bulbs for the ABS and the Airbag appeared to be a bit different from the others. They had a twist lock base but the bulbs were not removeable. So I purchased 2 new twist lock bases and put some LEDs in there. Now the indicator lights constantly stay lit. Any thoughts?
gerard
led cluster mod
gotta quetion for you guys.when u do ur led cluster mod the light that u take out of the cluster do they come right out of the original socket or do u have to get special sockets for the leds.The only reason why im asking is because my bulbs r soldered on to my socket but every where that i have reaschered they should pull right out.
gerard
The problem is that the light. Bulb is soldered to the twistlock socket so I can't pull the light bulb out of the socket.
2010georgiacrew
I just tried this mod on my 97 Tahoe and none of my dash lights are working now. What do I need to check? Fuses are good.
RockyD95
