Interior Light Problem
992door
Greenville, NC
Do the lights come on when you open the passenger door by itself or the rear.
I know mine come on when they want when they want when i have the door open. Half of the time when i open my door no lights come on i am just to lazy to replace the sensor or whatever it is
Billy_ocean04
Billy_ocean04
Michigan
When I open each door individually it's still the same. Passenger door lights are still out. Even when I toggle my dimmer switch it's the same result
ZeroCool
I have the same issue! Posted another thread a few days ago
TigerEyz3
Slow and Steady
TN
If it's just the passenger doors (all others areas light up as expected), I'd make sure the bulbs in those doors are working (not burned out). If the bulbs are good, you've got a wiring trace ahead of you to make sure nothing is grounding out and that all connections are solid.
My Tahoe has door switch issues - as in the front door switches don't seem to be functioning properly (all bulbs light when the switch is triggered). The most used doors are the ones that typically have this problem. Just a heads up... BTW, my Tahoe has 250k miles on it, so it's seen a lot of door opening/closing cycles.
gonzo51501
