Interior Lights problem
95BlackTahoe
Edinburg, PA
I had that issue on a old 77 suburban that sat...Cleaned up all the grounds and things started to work again... Check those grounds, its amazing what they can cause...
Shawn
aidandj
aidandj
Portland, Oregon
Sunlitow would I go about checking the BCM because I removed everything I added and its still not working. Also if it makes a difference the fogs aren't working either, neither the lights or the light on the switch turn on
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Let's first make sure you have one. Look under the steering column or remove the panel below it to see better. See if you can't find a box with several multi wire connectors on it. We will for now assume a base model a z71 does not really specify luxury as it does suspension. I will trace and look at the fog circuit diagram for you as well.
aidandj
aidandj
Portland, Oregon
I took some pictures up under there, I think I might have a BCM but not sure. Here they are:
SunlitComet
OBS Jedi-Do Good
That is the interconnect on the steering column for all the switch assemblies on the column. What is the big bundle of wire tied up in pic #2?
aidandj
aidandj
Portland, Oregon
Sorry it's been taking me so long to reply, I just started a new job right after finishing school. Sunlit, any ideas on what it could be?
Thanks,
ADJ
