Interior lights stuck on
SunlitComet
OBS Jedi-Do Good
unknown at this time.
uh before you cut any wires why don't you used the defeat push button on the headlight switch. when the button is locked in the interior door switched lights remain off even when i door is open.
druiddonn
The dome override only stoped them from timing out.iv added a swich in the fuse pannel using the open space but mite look for a photo cell switch.it should be easy anuf to remove in the future
druiddonn
And thanks for the help its the third or forth time you bailed me out
SunlitComet
OBS Jedi-Do Good
if it was working properly it will stop the lights entirely as well. if it is not doing that then something is broken. note that if you open the door then lock the button in then you have to wait for the timer to shut if off. afterwards they will not come back on.
pewtermetallica
