Interior paint on dash chipping....
cbettis42
I have some spots on my dash where the paint has chipped off... Has anyone had this problem and fixed it? If so, what did you use paint-wise?
Mr.Jack
Norway
Btw. Is it posible to paint the entire interior? Dismantle all the parts and spraypaint them? Black interior would be cool.
DylansBase
Im also having this problem, the paint on the passenger side is coming off. But i do not know how to fix this. If anyone informs you on how, let me know. It will be greatly appreciated
Stormtrooper10
Sacramento, CA
I had this problem and it is possible to spray paint all your interior black or any color you want to just use primer first and it looks great on mine.
Doomsta510
510 Albany/Richmond Ca.
I'm sure you could spray it the same way you would spray your dash face, sand it down spray it with a good adhesion promotor, primer, paint, then some clear to protect it from scratching or chipping.
C
cbettis42
hey storm did you repaint your whole dash or just the spots? is there a certain paint that is best?
WildBill
Google automotive interior paint or dye. There is specific stuff that for paining interior plastics. You can get stuff that matches the OE colors pretty close, or go custom. Make sure you put time into prep work and get off all the armorall first. then do the adhesion promoter and paint. I would only do clear coat if you do a bright color.
dont use regular spray paint, it wont bond to the plastic and will chip again, plus it isnt flexible.
Saucy_Walnuts
