PNWYukon
Has anyone replaced only the tiny u-joint in the intermediate steering shaft? Where can you buy a little u-joint for it? Or have you repacked it successfully?
I think u have to buy the whole shaft. I replaced my whole upper one. But not the lower. If that’s what your talking bout. The joint that connects to the gear boxHas anyone replaced only the tiny u-joint in the intermediate steering shaft? Where can you buy a little u-joint for it? Or have you repacked it successfully?
Yes, I see that is the standard. I was curious if anyone has tracked down the little u-joint and replaced it. It is the upper one just inside the firewall above the brake pedal.I think u have to buy the whole shaft. I replaced my whole upper one. But not the lower. If that’s what your talking bout. The joint that connects to the gear box
Because, although a new one is $60 or so, it seems silly that you can't replace that little u-joint.Why would you even want to try and do that its cheap enough to replace the whole shaft.Their is an updated one also if you have the original still on it.
OG white one.Does it have the updated green lower bearing or does it still have the white one?
