2011 Yukon with 36k, Goodyear Wrangler HP's. At low speed I've got a "rumbling" sort of sound from the front end, only way I can describe it, but noisier than my liking.
Had the local good tire shop look at them and told there's a little "choppy wear." Balance and rotate, same and same, no change.
I'm not definitely sure it is the tires, or not. I had read where some model Denali's ahve this sounds, but from the front bearings?? The noise just bugs me cuzz I'm sure this imparts some level of wear in the running gear.
I will soon need a new set of tires as I'm running thin on tread. Cooper Discoverer CTS has been recommended.
But where's this %^$ noise coming from?
