is my temperature normal? (see attachment)
McFizzl
Broke as a Joke.
Fayetteville, AR
Check out where my truck runs when its warmed up. It seems like it should be higher than that...
Donnie Yukonie
Yates Caretaker
Yea should be a tad warmer Mine sits 2 ticks below 210
jdpber
GOLD MEMBER
The America
190 is the common GM 350 temp that's where you want to be when engine is warmed up
retorq
Kingman AZ
It depends on your setup. I run a 180 thermostat, massive fully welded AL radiator, high volume pump, electric fans and a custom shroud, mine sits exactly where yours sits when warm. If I get on it going up a hill it will raise a lil and if I sit in traffic for an extended amt of time (or siting at the drive thru ATM) it will hit 210 and the fans will kick on.
19Yukon97
Texas
Mine runs about 2 tick marks above what yours is showing.
McFizzl
McFizzl
Broke as a Joke.
Fayetteville, AR
It runs about one stick over the 1/4 mark normally. It wasnt fully warmed up but it never really gets any higher than this.
GA_Boy
Leesville, LA
Mine seems to want to stay right around where yours it at, it might go one tick mark over but then it goes back down when I am driving around all day.
