Is the s terminal purple starter wire grounded?
chicagochuck
2000 5.7 tahoe
I am having trouble starting my motor that I recently swapped in. The positive terminal on starter has constant power but the s terminal is not getting power when the key is turned to the run position.
I used my multi-meter lead on the purple wire terminal and the other lead on the positive battery and I got voltage meaning the purple wire terminal is a ground. Is that normal?
Iv been trying to figure this out for a few days, checked all the fuses , crank fuse, starter relay etc. No crank no start.
Njoppy
