Is there a direct fit, upgraded transmission cooler out there?
ToddEdge
Trophy Club, TX
I'm looking to upgrade to a much larger transmission cooler on my '07 Denali. I'm not looking to make modifications and change hoses, etc. Is there an upgraded kit that simply swaps in without tons of extra work? I've seen reference to Tru Cool but, not sure if they are a direct fit or not.
Thanks,
Todd
Pooter
DFW, TX
Tru-cool is a tab more work than the NNBS silverados just because of the core support/hood latch bracket space being less room to work with but its not bad.
I added one to my '12, I did not already have the OEM towing package with the factory cooler so I used the derale fitting and just used rubber line to run to the fitting at the radiator and back to cooler, ran up under the plastic core support cover to keep it clean. Painted it black, cant even tell.
Cooler has kept my temps under 150-155* beating on it in the Texas heat, before the cooler, 195-205 with even just normal stop-n-go driving.
CoopDogg
