I have an '05 XL Denali with Y91 / digital amp. I've replaced the head unit with a Pioneer and the PAC RP5GM11 setup. All works fine, but I am planning on replacing the door speakers and using an aftermarket amplifier for the front stage and the console sub. For other cars I've owned, I've been able to find "amp-bypass" or "amp-replacement" wiring harnesses that will plug into the factory wiring in place of the amp itself and give you pre-marked speaker terminals and turn-on and in some cases even usable power and ground.
I haven't been able to find that being offered by the usual Metra/Axxess/PAC suspects, but wasn't sure if there's anyone else out there offering this sort of adapter. I very much don't wish to cut all that apart if I can avoid it!
If nothing else, what's a reliable source for a wiring diagram in 2022 for an '05 truck????
