is this a problem free/recommended 2/3 drop kit
Max
Mile High
Denver
3/16" no need for threading them they just pop on, I just bought threaded rod because it was cheap from napa.
Fyrcaptain
Richmond, VA
Max....I know you have tried just about every combo out there....when you were sportin stock aircraps and a drop.....did you get the AR rod length for the different drop amounts?
Does a 1" shorter AR rod give you 1" less of lift
I'm wonderin how much I could shorten it with the stock suspension to keep it from going ass end up when the compressor cuts on.......
Thanks
Max
Mile High
Denver
You'll have to adjust them a few times, I wanna say it took me three tries before I nailed it. They were really short with the 5" before I swapped to the bilsteins.
55belairtim
Supporting Vendor
WHAT SIZE all thread is that? Looks like 1/4" NPT...and also what tpi (thread per inch) 20(course) or 28(fine), if it's 1/4" NPT.
Pat
hi
just adding on to this for future referenc
1/4" npt (national pipe tap) threds are 18 tpi
1/4" nc (national course) is 20 tpi
and 1/4" nf (national fine) is 28 tpi
npt (national pipe tap) found on all pipe related fittings (almost never found on bolts or nuts)
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
im doing a 3/5 kit on one on friday ill put up some pics for you all djm :)
09YukonHybrid4x4
