SunlitComet
OBS Jedi-Do Good
save for the whole CAI. A KN CAI (they call it the Fuel Injection Performance Kit too) for our trucks is $235 at amazon like I mentioned above. It replaces the whole intake assembly.
Right off the bat make sure fluids are clean and level with no sign of cross contamination. If your t-case fluid is always to high and your tranny keeps getting low at the same time there is a seal between them that causes the problem. Front end wear can happen in several parts at the same time so A one part fix may not get rid a steering problem completely. If you ass sags (they were higher in back when first built)you could benefit from new spring packs(always in pairs). Make sure all your electrical grounds are clean and intact.
From your picture you can benefit from some new light lenses as well. May be door hinge pin and bushings(pain in the ass)on driver door.
So far it looks pretty good.
---------- Post added at 01:16 PM ---------- Previous post was at 01:15 PM ----------
If you are curious about something feel free to ask here anytime?
