Just did LED dash replacement even 4wd select
boozer
Wichita, ks
Just replaced ALL the lights with LEDs in the dash. Even the 4WD select that does not come apart. Snipped the bulbs off and it left stubs of the old bulbs. Soldered LEDs directly to these and found the Gray wire off the connector was power to the lights. Added a 330ohm resister and it worked great. So here are a few picks, also changed my radio to blue it has color changing built in.
For those that have asked you can't change the gear selector with out completely redoing it, each part is a separate LED. I checked today it would be a real pain.[/QUOTE
I have already done the cluster and was getting ready to do the whole dash white. Question is what resistors were needed for the rest of the dash and the window switches
Dornan
