Just Fishing's 09 Tahoe Build thread
Just Fishing
Just Fishing
Can't fix stupid
Utah
First attempt at doing SS AN lines.
Success!
I used some green masking tape i had laying around to apply to the braid.
Then used my die grinder to trim/cut the end off.
I left a thin ring of the tape in place for assembly.
and used some dielectric grease to lube the fitting, being careful to not push/ooze it into the hose during assembly.
I have one special -an adjustable wrench.
it worked great, used an evil energy branded one since it was less than $30 shipped off of amazon.
I decided the single an wrench won't cut it, so another one is on order.
pwtr02ss
Tennessee
Success!
I'm not sure if the official tool to do this is a miracle or if it sucks all together. If I ever do that shit again, I'm buying the tool.
When I did my ls swap on my 74, I did all braided fuel and trans lines. Wrapped it super tight with electrical tape, then cut with die grinder. Forced the fitting on, yada, yada, yada. By the time I got all the lines made, my thumbs full of holes and bits of wire from the braided part fuzzing up. Out of everything I did to that truck (full frame off resto), that was the part I hated the most
Just Fishing
Just Fishing
Can't fix stupid
Utah
These went together pretty smoothly.
I'm remembering loosely a video I watched months ago when doing it.
I recalled masking tape for the ends in the video... so i ran with it.
I thought electrical tape for a sec but decided it would probably bunch up on me.
I was able to do a nice tight wrap using the masking tape, but it's also an auto body grade stuff.
Sticks really well.
and it was difficult to trim to a thin ring, stuff didn't want to let go of the braid.
I was also worried that the stainless braid would be very tight (reading reviews for fittings)
These fittings were "Evil energy" via amazon.
they are -8an lines, but the one larger end for the hose connection was -10 for the wrench fitting.
I'm hoping my other connections go just as smooth. :jester:
pwtr02ss
Tennessee
Sticks really well.
I think I used jegs and russel brand fittings. Russel brand hose. I did -6. Had fittings to return less style fuel filter then to fuel rail. Trans I did to hard lines I bent all fancy like from radiator to inside the frame rail. I may have had a beverage or 6 when I was doing it
Just Fishing
Just Fishing
Can't fix stupid
Utah
Lol yeah,
I'm planning to try the fancy bends for hard line.
And only use the braid for areas where i think it will need flex.
Pretty much planning to copy the factory line, but with the larger -8
We shall see how well that goes. :jester:
Last time i did this, i found it was one trial run, and then a final after the trial run was all sloppy looking because i made the bend too far out, or too short.
but that was with -6 an
I expect this to be a pita.
:yaoface2:
Levi0320
