Just Fishing
Can't fix stupid
Random find while looking for more detailed specs related to clutch pack clearance.
Lots of good info there.
Doing a check on my clearance, I'm a little tight on one, and in the middle range of others.
There does not seem to be any real selective options available.
As it sits, everything should be fine.
But I'm more concerned with the tight clearance of the low rev clutch at the back.
Part of my mistake was saturating the clutch packs in fluid before installing.
Cleaning and drying, i get a good .048 per my dial indicator.
Spec in atsg says around .050.
Per the link, I'm good.
But i would rather have the clearances a little more uniform.
Rest of the packs, I'll see if i can't tighten them up just a little.
But I'll wait until i confirm end play since this will be another order and a wait.
Might as well get shims on order with it.
Gears Magazine - The Devil's in the Details! A Machinist's Look at the 6L80/6L90 Units
The 6L80 and 6L90 transmissions have become the most popular rear-wheel drive GM transmissions in most of our shops. We have seen several patterned failures, written numerous articles, and found countless fixes to keep these units on the road (and the list doesn’t end). With so many of them in...
gearsmagazine.com
