just got a 99 escalade and can’t find much info on it
YukonGTmaster
Nice Truck! For replacement body and interior items I would check out LMCtruck.com . If there are no obvious coolant leaks, I would do an engine oil change, transmission fluid/filter/gasket. And front and rear differential fluid change. Put a grease gun on the front end components and driveshaft. Check air cleaner and pump up the tires! Should be good to go. If you notice coolant levels going down or leaving a stain on the driveway, that might be a whole other project.
Almo7annad
