Just got some 32" tires and have some brake questions
skyhighsami
I turned to torsion bars for an additional 1 1/2" lift. Now the back is 2 1/2" lower. Will a 3" block do the trick? Should I get a pinion angle corrected one for a 3" lift? The wheels are Mickey Thompson Classic and my next question is brakes. The front needs pads. Should I get replacement pads or swap the 3/4 ton calipers and get braided lines? What's needed to make the 3/4 ton calipers fit and where's the best place to get the lines?
conrual777
