Just installed Range device, potential issue
scomis
2009 Tahoe 5.3. 175000 miles. I have owned it for a month and a half and have not heard a single tick. I bought a range device, plugged it in yesterday and drove it to and from work. Loved the subtle differences in how it drove.
However, when I started it cold this morning, I noticed a small tick that lasted about 10 seconds. Any ideas as to why this would have happened? Is the Range device reducing the oil from the top of the motor and causing issues?
I unplugged it for now, so I can check it on cold start tomorrow.
I bought the Range device to try to be proactive and make the motor last many more mile before any ticking developed........ not immediately cause ticking.........
S
scomis
I was just googling about this. Something mentioned it could be piston slap that was masked by the AFM previously? Now that it's disabled, it's noticable?
mikez71
It won't enable until the engine has been running for 30 seconds, and won't enable in Park/Neutral unless vehicle speed is below 0mph, so I don't think it will enable at all in Park/Neutral..
Probably coincidence..
j91z28d1
what doesn't engage, the range device or afm?
has it even been sorted out what commands the range devices are sending out?
I wonder if the hood switch mod would keep it from going into afm and still pass the emissions monitors.
for the op. it's much nicer to have afm turned off in the tune than the add ons. I don't have any idea what command it's sending out to the ecm to keep it from going into afm mode. but since it does keep the emissions monitors from setting. it doesn't seem to crazy to think it's possible piston slap part of the ecm cold start routine doesn't run. but I would have no idea how to test that.
S
scomis
I ended up using the Range yesterday too and then the cold start was totally normal this morning. Who knows, maybe the ticking yesterday morning was totally coincidental........ I will keep monitoring it and see if it does it again.
Chevgent559
