emay
Burban has a buyer and the suspension is not part of the deal so I'm pulling it off and returning the truck to stock.
This is the physical system Yates had on his yukon. I bought it from him the first week of April.
Full bolt on air suspension for 07+ Tahoe, Suburban, Yukon, Denali, Avalanche, and the front will work on NNBS 1500 series trucks. Yates had repowder coated the suspension parts, included new fittings and air lines, also included the front bags already mounted on struts. Your getting everything essentially refreshed as of April 2012. The kit uses sleeve bags on the front and regular bags on the rear. The air tanks, valves, and compressors all fit where your skid plate is currently located. The kit uses AccuAir E-level controls so your truck is always at the perfect ride height and also is adjustable on the fly. The kit comes with dual Viair 400C compressors and has an air dryer on it.
If you own a truck with factory air ride then the oem sensors work great with this system. Mines done this way. If you have a non air ride vehicle then you will need to get a set of air sensors, I've got a question out to Derek to see what those would run so there are no surprises.
I can ship via UPS or on a pallet using a local freight company cost is on you.
I am asking $3250 plus shipping for the kit net to me. If your using a paypal type merchant, the fees are on you. Let me know of any questions.
More pictures of the kit off of Kelderman website. http://kelderman.com/node/145
Pics of the kit on my burban - These pics are with the rear handling kit offered by norcal. I'm not including that, but the shock extenders will net you 1 full extra inch out back and the stance will look as follows:
On the Roll...
This is on a preset I set and use for daily driving.
On the Roll...
