Keys + Spacers, Largest size tires?
Yukonboy03
Memphis, TN
Hey fellas,
I'm in a 2003 Yukon that I put Suspension Maxx's Keys and Spacers in. I currently have 285 A/T Revos and am wondering if I can go any larger.
I know I would probably need new wheels but what is the largest size you all can squeeze in there?
Thanks,
John
BlueTahoe2001
Charlotte, NC
Hey fellas,
Thanks,
John
Check this threead out-
http://www.tahoeyukonforum.com/forum/showthread.php?p=224039#post224039
With 20x8.5 Rims and the correct back-spacing you can fit 35's if you want. All this info is in the thread that I posted above.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
with stock rims you can fit up to 35s. Aftermarket rims you may want to stick with 33s or 34s
Yukonboy03
Yukonboy03
Memphis, TN
So with my stock wheels I can put even larger tires on? I was already rubbing slightly with the 285s and had to trim a little of the front side of the wheel well.
How would larger tires not rub even worse?
I am going to be honest, I know very little about wheels and tires.
Thanks,
John
QUYHMK
