killer20072001 System build
killer20072001
Oklahoma
I took some 400 grit and sanded the piss out of it, to get most of the texture out. Cleaned with warm water and soap, then laquer thinner. Primered it sand with 600 primer again then sand with 800 and primer again, sand again with 1000 grit, and it should be all smooth just clean and prep again then your ready to paint. Lay a couple of coats of paint and then clear. Wet sand the clear with 1500-2000 grit and buff and polish. O yeah something I didnt do for it but would help is use adhesion promoter. Mine is starting to crack now and adhesion promoter deffinantly would have helped.
NoPh33rRaCiNg
Kent, WA
You wanna try and keep the sub's as far away from the port as possible. Looks good, i'd have em mounted toward the front of the box.
killer20072001
Oklahoma
Gotcha gonna move the subs towards the front, move the side to side dowl rod down instead of so close to the top, and the 45's going side to side instead of top to bottom.
This is what I got done today. The only thing I have left to cut is one more of the port and top cut.
All you need to build a box
Top/bottom
Sides
Front/Back
killer20072001
Oklahoma
Here you go fellas. Im getting there, but I have no more screws and its too late for the hardware store to be open. Hopefully tomorrow I can get the port painted top on and routered. ****** phone pics.
chip
Tampa
I love the detail in this thread. The pics are awesome! Great job!
gdddup
NJ
good work cant wait to see it installed
Suburbans
