Knock Sensor
dinoedwards
Seen plenty on relocation of KS and was going to put mine on the heads on empty bolt holes, some swear by it some say no put them down lower.
My "03 is 2wd so not that big a deal except for one by starter looks like a bear?
if you use new oem sensors and a new harness, you should only ever have to do them once
frank1
I did the relocation on my 05 and 02 trucks, works fine. Got the 10mm couplings on Amazon
Aren't both of the knock sensors on these under the intake manifold? The camshaft position sensor is behind the starter.
72seth
