L94 to L96 engine swap
D
davebarky
Thanks for your reply. Earlier 6.0s like the LQ4 and LQ9 didn't have VVT, but later engines L96 and LY6 do have it. As far as I can tell, those are the only engines that will swap in easily.
D
davebarky
I finally got this done a couple weeks ago. Thanks to everyone here for your input, especially Swathdiver. Your assessment was spot on. This was plug and play with the tune, runs great on regular gas. I think we're going to go back into the tune a little, we just used the stock L96 parameters. Gas mileage is down about 2 MPG, but O2 sensor and fuel trim data look perfect on my Snap on scan tool. I'm thinking that the premium fuel L94 with more aggressive timing may just be a bit more efficient. Anyway, I'm very pleased with the results and the increased bottom end torque is noticeable.
Geotrash
Dave
Richmond, VA
Wonderful news!!! Thanks for following up. Nicely done.
j91z28d1
so rare someone follows up a thread above how it turned out. much appreciated.
I was going to ask why not go with a iron 5.3 for cost savings and fuel mileage? just curious
the 6.0 you went with, was that rectangle port heads like the 6.2? or Cathedral.
did you find out what the noise in the 6.2.was?
petethepug
Michael
SoCal
World's best way to turn a 1/2T full size SUV into a better hauler. It'll run on regular and crank out 360 hp. If it's the later e85 compatible motor, you get 322 hp the BCM will detect for you. Like the link says add a cam and expect another 100 hp.
Buy a 10-14 Escalade Platinum or Premium 2WD with a blown-up motor and factory equipped dual exhaust, drop in a tuned L96 set to run on race (e85), regular for towing or premium and you've got the world's best budget Luxe hauler.
Joserobles27
Bolts right up, same manifolds, same heads, same intake, same flex plate, smaller injectors and 80 pounds added to the front end for the iron block. Tune it and go.
Use the Hummer motor mounts (25847739) while the engine is out and consider a billet torque converter with the improved Sonnax parts.
sorry to bring up a old post i'm curranty in the same position. Anyone know any good tuner to help me out ?
Snefferz
