Largest tire on a 2015 Yukon with leveling kit?
NowZoomer
275/60/20 on 9.5" et30 wheels, kept me at the same exact outer position as stock wheels (I find stock to be almost perfectly flush with body and didn't want to ruin that)
I'm running KO2s and love them
I think you may rub with your rim width though not tire size
WillieFlo
Houston, Tx
Nowzoomer, Whats your 33 setup? I have a 2015 Yukon denali with the stock 22's and want to go with 33x12.5 22 toyo's. If the 1.5 leveling kit will do it then that'd be great. Any complaints? my other option is to drop down to a 20 and just do the 275 55 20's but i like the look of the 22's.
2001ws6, I'm also considering the 33x12.5R22 Toyo MT's except on XD811 Rockstar II's with +12mm offset in Satin Black......looked all over the internet to see what they'd look like, but no dice. Love the look of 22's on the Yukon and really don't want to go 20's, but I'm torn as well....
Would love to see a set of Black 22" wheels with 33" tires on an Iridium Metallic Denali 4x4....
massivespl
I'm not mean, I'm honest.
Michigan
http://www.gmfullsize.com/threads/ck375-and-33x12-50x22-toyo-open-country-mt.262741/
Some good pics in this thread^
Edit never just realized this was the 2015 section lol
2001ws6
id think i could go leveling kit and thats it before my wife complains. I think toyos on 22's on the denali would be badass but thats a lot of money to throw done the drain if i can't make it work. I just got the rig in december so ill run the stockers down first anyway, maybe someone will beat me to it.
WillieFlo
Houston, Tx
I am looking to buy a 2015 Yukon and want to level it and run the largest (tallest) tire possible. Does anyone know what tire that might be? Here is a pic of the 4x4 Yukon I am buying.
Denton,
Did you end up getting the Yukon and leveling it?
EnigmaMan
Yeah i usually end up getting crickets when I ask technical questions as well.
Ive got the 2.5" front leveling kit with 1" spacer in the rear and will be running 285/70R17 (~33" tire) From my measurements - no rubbing in the front / back
Good luck!
EnigmaMan
Does anyone know if 17" wheels will fit on a 15' burb?
LOL they have not change the bolt pattern on a Yukon, tahoe, or Escalade in over 10+ years They are all the same 6x5.5
I doubt they did a big brake upgrade on the 2015's that would keep the 17" wheels from working though.
PD2770
