Last a/c question....I swear!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Use the whole site you will love it. As a matter of fact if you don't have a build sheet run you vin under the research page's vin decoder.
S
Stresst
No, no, no. No pun intened even thou after this mess I need some laughter. Someone in a thread somewhere mentioned to make sure there is only one orifice and to confirm where it is.......
taylorjm
Saginaw, MI
I actually found a solution to your a/c problem.
S
Stresst
Great idea, the rear windows are pretty much useless anyway!!
SunlitComet
OBS Jedi-Do Good
Number 21 in same picture. the rear unit uses a thermal expansion valve.
S
Stresst
Yup, got it. Even im not that bad.
My only issue looking at this picture is I just purchased new cycling switches, hi and low cuttoffs. One is p/n 15-2962 and the other is 15-2832 kinda confused now.....
SunlitComet
OBS Jedi-Do Good
the 15-2962 should go on the accumulator. It is what actually does the cycling based on pressure. I don't see the 2382 any where but the other two are out right safety cut offs. Another performance test for you to take some stress out of your name.
S
Stresst
the 15-2962 should goe on the accumulator. It is what actually does the cycling based on pressure. I don't see the 2382 any where but the other two are out right safety cut offs. Another performance test for you to take some stress out of you name.
Must be nice and chilly I mean nipply in that car! lol
SavageWarrior13
