Leaking hoe
Dowsewashere
Hello everyone. 1998 chevrolet four door tahoe. My cargo area was wet and i relized that the rear glass on the left was leaking. Had it replaced and thought all is well in the world. Comes today it rained last night and this afternoon i found more water... Not as much and i checked both windows and neither leak. But theres water, ANY suggestions to where its coming through?
Edit- could it be this gasket near the tailgate?
The screw driver points to the gasket that may be the culprit. because ive used a hose to check all the other windows, i think it may be when i drive.
Sentry
Could be the rivet nuts for the luggage rack on the roof as well. I think that is where my leak was coming from. They get old and the seal wears away from heat...
Mind you I'm no expert, I have come to this conclusion after removing mine and seeing their condition.
D
Dowsewashere
i actually noticed its the weather stripping around the rear hatch.... god i hate this
raptorforme93
Tampa, Fl
Let me know how this pans out, my 96 2 door does this also in the cargo area and I cant tell if its the hatch seal or if its coming in through the roof rack so I still I have to look into it
Gzes
the drifting 2dr
Wichita tx
Mine was the seal on top of the hatch. I just had to clean it good and it worked again. I had leaves and whatnot in mine since it was sitting for years
97ext
