LED bar behind grill
I have pondered this idea. Although I was thinking of using the factory fog light wiring. Does anyone know if the wiring/relay system would be heavy enough for such a lightbar? Pro's and Con's of using this set up?
I had (2) 8' on my 2000 Yukon in place of the factory fogs and it ran off the stock system just fine, but if you think a bigger bar might be to much for it then you can still use the factory switch and just run a relay very easy to do and it takes the stress off the factory system, the relay just makes the factory button a on/off control.
MattGallion
Thinking of doing this and using an on-off-on switch so I can select between On, Off, and On with High Beams. Only issue I'm having is figuring out where I can tap a signal wire from the high beams circuit. Anybody know?
I know I could do an add a fuse to the high beam fuse in the engine fuse panel but I'm not sure if that's the best idea.
sarneson91
Alexandria, VA
I shoved a 42” behind my grill, clears headlights by 1/4”. I put my switches up where the garage door opener unit is, well between it and the lights will post pic in 30 seconds
Denton
Waco, Texas
I just bought a 40" curved and put it on my Civic as a trial run. Will be installing it behind the grill of my Yukon soon. First pic is headlights only, second pic is light bar only.
Denton
Waco, Texas
No, HIDs just turned them on plus windshield is 40% tint
Sent from my SM-G892A using Tapatalk
Denton
Waco, Texas
How long did the install take? I am going to try to install two 40" light bars behind my grill next week. Hoping there is room.
Rome58
