LED Cupholder
Clean07Burb
I know it's been a while LTLux, but did you ever find out which wires your friend had to tap in to?
You should be able to tap into any wire that is hot only after the dash lights come on or after you've manually turned your headlight switch to the on position. That way the cup holder accent lights will only be on when they need to be.
PistolPT
Thanks Clean07Burb
Wolveinemech
