LED Headlight Interference
Jason101
I just upgraded to LED Headlights and Fogs two weeks ago and have no issue at all including what you are describing.
Both were plug and play without any additional capacitors or anything.
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
I just purchased some H11 LED bulbs and replaced the halogen bulbs in my 2018 Tahoe projectors. Although the light output is decent and cutoff/beam pattern is good, I'm running in to an interesting issue that I wanted to see if anyone here had experience with.
These LED lights interfere with the back-up camera. The image becomes shaky and grainy when the lights are on and returns to normal when they are off. No other interference with radio or otherwise.
I've tried ferrite coils on the wires and even tin foiled the dust caps to attempt to diminish the interference, but with no luck.
Is anyone running LED headlight bulbs that don't cause interference--or have you experienced this issue?
Hello subsonic. Glad you are pointing out this, our kits has been tested one of the best kits out there with no issues at all not even the ones you are having! Out kits are 100% plug and play and error free as well. You can buy ours which they also have a very good reputation and trustworthy reviews from real buyers here on the forum . Let me know if you need any help or have concerns . Thanks
SubSonic
SubSonic
DFW
Just wanted to update that this issue was solved by using different LED H11 bulbs, so obviously just a bad set with interference.
Tahoe_Tito
Mind sharing brand and source? I’m looking to get LED bulbs and don’t know which to go with.
Jason101
Sure Can. Still no issue. Absolutely love them.
Headlights:
OPT7 Fluxbeam LED Headlight Kit w/Clear Arc-Beam Bulbs - 9006-60w 7,000Lm 6K Cool White CREE - 2 Yr Warranty https://www.amazon.com/dp/B00VNBDVOC/ref=cm_sw_r_other_apa_Uio3Bb9E3E223
Fogs:
LASFIT PSX26W / 12278 LED Fog Light 60W 7600LM/set 6000K Crystal White Flip COB LED Chips 1x Pair (2pcs) https://www.amazon.com/dp/B079CBR2PX/ref=cm_sw_r_other_apa_dno3BbFZBXN5Y
bruh2125
