Huntin Truck
This weekend I went and changed all the interior lights to LED's. What a difference!!! I changed the dome, door, window switches, HVAC and instrument cluster. Everything is red except the warning and indicator lights on the cluster. I made those blue. It looks great. I'll post pictures tonight. I did leave the map lights white just in case I need the light. The only thing I couldn't change was the 4x4 switch because the lights were soldered in. I'll be looking to change those soon.
The biggest piece of advice I can give is to remember LED's are sensitive to polarity. If you put one in and it does not work you will need to rotate it 180 degrees and try it again. This is trial and error process. Unfortunately there is no way to tell polarity.
